It is currently Tue Jul 29, 2025 9:22 pm
 Post subject: Fret slotting systems
PostPosted: Sun Sep 21, 2008 4:59 am
Has anyone got any preferences on which fret slotting system to buy?
I have looked at the stew mac and luthiers mercantile ones. Are there any others?
As well as guitars and mandolins, I am looking to make an octave mandolin with a scale length of 515 to 540 mm.
I understand that a guitar template can be used by starting further up the template, can anyone suggest which template is most suitable ( I intend buying a Martin 25.4" anyway)
PostPosted: Sun Sep 21, 2008 6:30 am
My fret slotting system....I try and keep it sismple...a spreadsheet with calculated slot positions, a steel ruler and a scalpel. Works for any scale length.
Cheers Martin
PostPosted: Sun Sep 21, 2008 6:41 am
I've always used the Stew Mac mitre box and saw, I know there are more sophisticated systems out there, as well as table saw methods. But if you just intend to do a few instruments then the Stew Mac one will work just fine after 30 or more FBs I still have no desire to 'upgrade'.
PostPosted: Sun Sep 21, 2008 7:03 am
I upgraded to the table saw method using Shane's blade and after 2 years, I'm very happy with the method. I use the 25.4/24.9 metal slotting template ... I believe I bought it from StuMac.
PostPosted: Sun Sep 21, 2008 7:31 am
I've used the LMI power slotting setup for years, and love it. I've never had any intonation issues, and it works quickly and flawlessly.
PostPosted: Sun Sep 21, 2008 10:32 am
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
LMI just redesigned their manual system looks nice still a bit spendy...http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Fretting&NameProdHeader=Manual+Slotting+System
Zac
Anchorage Alaska
Finshed my 1st! See #1 here
PostPosted: Sun Sep 21, 2008 1:46 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use Lmii & Stew Mac templates but with Shane's blade.
His is just slightly wider and is less apt to cause a wedge affect on the neck by the frets being a bit tight!
I made a plywood sled for my old 9" sears saw & that's all i use it for!!
Perfect slots everytime!!
I got tired of cutting by hand after guitar # 90-took me 30 minutes to do it right-I can slot 15 boards now in the same time with much more precise slots!!
mike
Mike Collins
PostPosted: Sun Sep 21, 2008 2:28 pm
Same here, Shane's blade with a simple homemade sled on a dedicated little table saw in the corner of my shop. The template was made from 1/4" stainless cut on a digital endmill, so it's dead-on accurate.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Sun Sep 21, 2008 5:51 pm
LMI's power system for the past 7 years, no problems. I think that metal templates will be more temperature sensitive than the Lexan LMI uses; not sure if the amount of expansion /contraction is significant.
PostPosted: Sun Sep 21, 2008 6:26 pm
Zak,
They made improvements AND reduced the price by $100. So it was originally overpriced. Now not so much. bliss
PostPosted: Sun Sep 21, 2008 9:06 pm
Here is a tutorial on building a fret sled and slotting the fret board using the Stew-Mac template.
http://infinityluthiers.com/tutFretSled.php
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Sun Sep 21, 2008 11:32 pm
I've been very happy with the LMI system. I made the table saw sled described by Sylvan Wells.
Terry
PostPosted: Mon Sep 22, 2008 12:33 am
Wood(Oak & Pine)- 0.0000027 in/in/deg F
Steel - 0.0000073
Polycarbonate - 0.0000375
Polycarbonate(Lexan) has substantially more expansion.
Thermal difference of 40º/18in fretboard.
Wood- .0019
Steel - .0053
Lexan- .0266
I'm amazed the wood coefficient is so small.
PostPosted: Mon Sep 22, 2008 12:36 am
First name: Zachary
Last Name: Bulacan
City: Anchorage
State: Alaska
Steel - 0.0000073
Wood- .0019
Steel - .0053
Lexan- .0266
but I bet if we take into account the humidity affect on the wood the other 2 end up much more stable
Zac
Anchorage Alaska
